Humdinger
- Joined
- Sep 22, 2012
- Messages
- 1,715
- Reaction score
- 587
Would someone with an original Gyruss mind taking a couple of measurements for me? I need to know where the bolts for the monitor side brackets protrude from the cabinet sides. If you will measure from the bottom edge of one side panel up to the center of the bolt heads, and then from the back edge of one side panel over to the center of the bolt heads, that should do it. Thanks in advance!
