animesuperj
Gunbird and Pole Position Projects - Waukesha, WI - $150
Time to clear out some projects. I'm looking sell both for $150.
Gunbird
- PCB works
- Control panel has been sandblasted. Also had new top installed so I didn't have to deal with the swiss cheese top. There are currently no holes. I have new overlays to go on this as well.
- Monitor works, but occasionally a couple inches will sag down and then snap back up.
- Cabinet is in decent shape. Doesn't have feet, so has been dragged on a flat bottom a bit. I have a leg levers kit from Bob Roberts to install, which will be included.
- The jamma harness was cut to use on another project. It will be easiest to just pull all the wiring and re-wire a new jamma harness. I have a new harness kit from Bob Roberts, which will be included. (The current wiring is a mess, it was cut/spliced way too much, which is why it'd be easiest to just pull and start fresh)
Pole Position
- Missing a monitor
- Assume pcb will need repair
- Cabinet is in decent shape. The guy I got it from put a bunch of screws in the back-top, but once it's against a wall/by other games, you won't notice.
- I had a monitor and semi-working boardset in it before (had a slight graphics problem and sound issue), and it played in this cabinet. I'm assuming wiring/power is fine, just needs a monitor and the board fixed. Don't quote me on this, but that's my initial assessment with it.
- Bezel and marquee are in great shape. Dash graphic is from PPII for some reason, could use a repro PPI graphic.
That is everything I can think of on these two. Again, these are being sold as projects, together for $150. Gunbird has most of the parts to get it running, just need to fix the monitor and install buttons and sticks. I just don't see myself working on them anytime soon. I'm located in Waukesha, near the hospital. If you have any other questions on them, let me know.
Gunbird
- PCB works
Pole Position
- Missing a monitor
