gun problem with lethal enforcers 2
Matt N
middle river, Maryland
I had 2 used guns from another game,i wanted to see if they would work I unpluged gun #2 that was the broken one player ones gun worked fine.now after i tried the gun which work now i cant get any of them to work including the player 1 gun which i never touched.when you pull the trigger the screen flashes & thats it.any ideas? thanks in advance!
Is the screen and the gun lenses good and clean?
Is the screen nice and bright?
When it flashes, does it flash "white" ?
Try running the calibration on them.
On a side note - Do you have a Gunfighters marquee? (I need a good scan of one)
Unfortunately, LE2 doesn't have a calibration menu.
If you hooked up a gun 2 and gun 1 stopped working, then I would check the power input/fuses to see if perhaps something is screwy with the voltages now to the optics. I don't think a short in gun 2 could blow the optic in gun 1, but you never know.
Turn everything off, clean all of the lenses, bezel, monitor, and mirror, and then try again with only gun 1 connected...
i cleaned the screen & the mirror also the lens on the gun & the screen flashes white when you pull the trigger.what i did notice before i had nothing was the gun wouldnt fire to the far left of the screen. the color on the monitor is bright & clear so not sure if i should adjust the color?
