Positive. MFD is an old abbreviation for microfarad, before they started using the "micro" symbol, which is the greek letter mu (µ). I would assume it has something to do with making abbreviations out of standard characters available to conventional printing technology. Most stuff since the 80's has been marked as µF, however.Are we sure MFD is uFD?
the 1600 VDC didn't freak me out on a monitor, the .01 uFD made me do a double take.
New ones are so tiny, just 35 years of progress?
Correct. But do mind the wattage. You need a resistor the same or greater wattage than the one you're replacing.It is labelled 100ohm, no K does that man 0.1 K?
Usually resistors burn up because too much current is being drawn through them. Look for a shorted transistor or something.ANd then I need to figure out why it is getting too much voltage that it can't resist!
