Guide to replacing a HV cup on a monitor
dezbaz
Donor 4 years: 2011, 2013-2014, 2016
Ballajura, Western Australia, Australia
I just had to do this on an old chassis so I thought I would document it
1. This guide assumes you already have the chassis safely removed and are still alive (See here if you need to do that first)
2. If you are getting arcing on your monitor, or you anode cup is cracked, damaged or just in-flexible, you can easily replace it yourself
3. We suggest you remove the chassis and do this on the bench, so solder doesn't drip into you other arcade components in the cabinet
4. Here is the chassis I will do the demo on (LAI BW Vector Monitor) LAI-KZ-20XYB
(Click to Enlarge)
5. Next thing to do is find a cup in good condition to use as the replacement
6. Here are 2 options off old TV Chassis' I picked up off the side of the road
I chose the 2nd one as it is closer to the physical style of the LAI chassis' cup
7. Next step is to slide the old cup off, without damaging the insulation of the lead. You want to keep the lead as long as possible. I used some of this WD spray to make it slide easier.
First you pull it inwards, cut off the spring, then slide it the other way, off the end
8. Cut the lead close to the spring and slide it off
9. Slide the new one on
10. Pull it out of the hole, holding close to the end so we don't shorten the lead too much
11. Pull the HV lead out enough to work on
12. you need to strip the wire without damaging the inner strands (I used pliers)
13. Desolder the old spring from the original chassis (If it is in good condition), as it suits the original Monitor anode hole
14. It will look like this
15. Solder tin the lead after stripping of 10 mm (3/8")
16. Bend the end and close it around the clip like this, prior to soldering
17. Solder the far end only so it remains flexible when fitting it later
18. Start sliding it back in
19. Push it gently into the bottom of the hole in the cup
20. Finished product
Time to perform the repair: 10 Mins
Time to document the repair: Longer LOL
@dezbaz I've needed to do this in the past on several Bob Roberts K7000 flybacks where they just apparently dryrot out and break apart. I didn't know about this thread, I just kind of figured it out on my own. cheers dude, thank you
Hmm ive yet to see this happen, only that stupid metal place holder thingy that falls off and gets in the way. I think I read a post that it was there to suppose to stop xray emissions or something idk, they are worthless and not needed.
