For Sale Guardians - Denjin makai II PCB - $100 shipped
I tested this tonight before wrapping it up and discovered a small issue with it. The P1 coinup is stuck in an "on" signal. So when the game boots you hear a coinup sound and the game starts with 1 credit. But because the signal is stuck in an on position, you can't add additional coins.
If you set the dipswitch settings to Free Play, the game plays fine/normal. You still here the coinup chime at boot, but everything works.
Maybe it's an east fix, not sure...if the freeplay setting doesn't bother you then it shouldn't matter.
