GT Live issues with video out
Brian12
Donor 2015-2016
Macon, Georgia
so, its older (2008) gt live...
Video output for the LCD screen works (the little one at top of game)
I will be putting this into a pedestal with a LED tv hooked up to it (main screen only) that ouput says invalid signal via VGA on the main screen output...I am plugging this into my flat screen in the house to test....only output that works is for the little monitor at top of game...
Bad video card? I plan to replace with a newer video card with HDMI.
Im just trying to make sure everything else works.
Bottom line i figure everything works bc it loads up 100% ok...so leads me to believe its the card being the little LCD video out works...I also tried all 6 dip switch settings and nothing from the main output.
-Brian
You have 2 settings for those Monitors. There both on the I/O board. one set controls the Main Screen and the other that small one. You may have the I/O board set improperly for the Main screen.
A LOT of these Older GT cabs ran EGA monitors on the main screen.
Yes, those were the dip switches I was changing for the main screen (I got the Manuel book) and no resolution worked..so ima call IT today..hopefully it's because the video card is out of date and I can replace it with newer one with hdmi (not a big deal and I want to use the tv speakers anyways might work out)
-Brian
What resolution are you setting on the dip switches? Try a few, and also check the dips for primary/secondary monitor settings.
I tried them all...I think (2008) my flat screen won't recognize the input format being so low via vga...but I know it loads up 100% (shows it loading on main screen ouput until the game starts the says invalid signal) think I just need to get a compatible video card with hdmi and will solve my issue...
