GT Fore RED PCB to GREEN PCB?
FrizzleFried
NAMPA, Idaho
I have a GT Fore cab wired for a red pcb using an ATX PS...
What would I need to change to run a green pcb?
From what I can see in the manual the green pcb doesn't have an ATX header so I assume I'd have to either wire in a standard Chow type switcher or hack in to the ATX harness?
Is there anything else I need to know? Are the controls wired the same, etc?
AFAIK the only difference is the power supply. I have a green and I seem to have a larger computer style power supply. Not the typical switcher with terminals.
just buy the red board and be done with it
if you change to a green board make sure you have a standard jamma harness.
some dedicated red board machines were missing the power side direct from it.
you will need a power supply and a power cable for the hard drive
I'm using an ATX PS to run a Green board now. I have modded the PS so that it is always on (Just jumper to wires together). I have 2 of the power connectors plugged to the green board and 1 to the HD. Easy.
