As the subject says, I have a green Gt fore board that will not get past low voltage error after hard drive check at boot up. It is not the power supply, tried a couple, yes it is the adjustable one. I have measured the 5v voltage at the boot eprom to be fine. I can adjust the power supply up and it will not change. So what can I check here? I'm assuming something is shorted.
Hope someone has run into this before. Thanks
