Grounding Question
plwagner89
Washington
Hello all! I have a quick grounding question. I'm rewiring my Bomb Jack and I need to know where to connect the ground. The ground coming in is connected to nothing and the green wire from the harness that goes to the coin door isn't connected to anything either. Do I need to connect a ground to the power supply, and if so where at? Also do I need to run a ground to the monitor chassis? It has a switching power supply in it. The wiring on this cabinet is all jacked up with 18 gauge wire inside for the 110 volt leads to the light, power switch and monitor. Thanks for all your help.
