Green Drive issue with a WG
Waterborn
North Myrtle Beach, Florida
I have a WG 4600 that has a green drive issue on my Pac-man cab. Basically no green whatssoever, so Pac-Man is red. Replaced the green drive pot and reflowed solder on the appropriate solder joints, but no luck. Also did a cap kit, still same problem. Anyone have any suggestions on what to check next?
Did you swap the chassis to a known good tube? Might be a bad green gun.. Also, reflow all the solder on the neck pcb.. Especially around the (3) trannies.. 4600s have the plug in red/green/blue on the yoke.. Make sure they are nice and tight..
Hope that helps
there are also 2 transistors that should be checked on the video card. also if you short out the green pin on you tube it should blast that color if the tube is good.
