Gravity Hill redemption settings, how to set coins??
markymarky99
Copperas cove , Texas
Yellow and red button inside.
Instructions are very poor.
Who knows how to change the machine to take 50 cents from 25 cents?
I believe I'm reading the manual right and should show 2 and 2 on the leds
Then what??
If I shut it off, it's the same setting as it was.
Is there something else to push to make the changes take effect?
Thanks , have the machine sold but the client needs it at 50 cents
I'm pretty sure you're correct... it should say 2 on both (option 2 for coins to start, value of 2 for 2 coins). I can test mine later if you need independent verification, but I'd suggest pressing the red button to go all the way past 8 to make sure it saved.
You're saying that you can change it to 2, but when you power cycle it goes back to 1? Or it always says it's 2, but only actually takes 1 coin to start? Do any of the other settings work/save?
DogP
