gravitar issue monitor/pcb maybee?
mr.fixit
arnold, Missouri
got a gravitar bro and it is smokin, litteraly lol, ok well it did i fixed that, ar2 issue, so it currently has no picture but game sounds,i coin it up coin counter clicks 1p start button flashes, attract backround noise of throbing works, thrust sound works, however i dont hear the enemy ships firing at the planet select hmmmm, idk. monitor its a 6100 , they never do work when u get them, spot killer, i get good voltage to chasis transistors except 2 2n3792s there 11.8??? found d807 iii belive to be shorted, r101 burned a hole clean through the pcb, was repaired befor i got it, and no hv obveously, the flyback has been replaced and the lead coming from it not the anode the other from the top has been cut down to a nub on the flyback is that normall? this is my first vector game , monitor does not blow fuses.
if you are not afraid to spend a few bucks getting that monitor fixed, pm slackmoe on here, he does great work. Fully trustworthy as well.
monitor
cool, thanks for the tip, if i cant fix it and he is cheaper than chad on arcade cup i will deffinately keep that in mind.
I have never sent a chassis to chad at arcade cup, but I have purchased a bunch of stuff form him. I am confident that chad is a pro.
slackmoe is a great resource and certainly will be cheaper (and faster I bet). He doesn't do it for a living though.
gravitar
ok, if i cant repair it then i will most certainly contact him then, should i say tron guy sent me?
