Gravitar help
squeakman
Lake Havasu, Arizona
I just picked up a Gravitar and when I picked it up the game was fully working. When I got it home it plays fully, but blind. The spot killer led is on on the rectifier board. I've done a bit of research and it says spot killer means no signal is getting to the monitor? Are there any things I can look at besides board repair to possibly get the picture back? I will send boards in if needed just wondering as a fairly new arcade collector if there might be smaller things I can look at to fix this? And this Gravitar has an amplifone monitor in it. I have confirmed all fuses are ok and reseated all connectors.
Have you reseated all connections since you moved it? Made sure they are all connected snug and proper?
Yes, when I got it home and realized the mo it or was blind. I can play the game without seeing it. Sounds, starts a game.
