Granny and the Gators
Mr Do
Donor 6 years: 2012-2013, 2015-2016, 2019, 2025
Basking Ridge, New Jersey
Plays blind sort of.
Not that is is blank or gray the screen, but it is alot of green horizontal lines jumping and I can play game and here audio. It sometimes turns grayish white.
I checked the monitor in my Baby Pac. So it is not that.
Is it the Vidiot pcb?
Also, can I swap vidiot pcb's on Baby Pac and Gators?
David
on the vidiot deluxe, there should be a pot marked sync. You can most likely adjust it until the pic clears up.
Before you go messing with pots on the Vid Del though, take a sharpie and mark their position beforehand. They're pretty tricky to get right if you get it out of whack.
You can swap vidiot to vidiot deluxe, but you need to swap the mpu as well.
