MostlyHrmlss
I got this machine from CraigsList, no idea of its history. I suspect that it's a re-import of a German export: It has the word "Foreign" stamped on the particleboard base plate that holds the power supply components, and a notice inside the head not to use a sound-and-speech board, lest it be damaged. Apparently some PO switched out the main board and sound board in the past, but left the original sound board power supply, which is not producing the right voltages now. I'm getting 6.8VDC instead of +12, 8.2VDC for +30, but the -12 and +5 are fine; the result is some pretty psychedelic sound effects. I was considering a replacement from PBResource, but it appears to have a card-edge connector, whereas mine has a pigtail connector labeled A7-J10, which connects to an inline plug labeled A7-P10.
So, I figure I have two choices: get one of the replacements and make an adapter from the exisiting pigtail, or fix the existing one. Either way, I'd need a schematic for this board that looks like a reject from a Flintstones trailer park (see attached pic). Can anyone help with this, or suggest something I haven't thought of?
