gottlieb system 80b help please
a_wookie
Farmington, Missouri
I had a call today on a Gottlieb bad girls that had been in storage....
I quickly noticed a burnt coil and removed it from the circuit.
I then replaced the fuse and got the coils going, the machine also had stuck relays and some other issues.
but my question is can anyone tell what transistor controls the left slingshot on a Gottlieb bad girls or where i can get schematics?
Pinball Resource
Good luck finding anything online, Gottliebs lawyars are very quick about sending cease and desist letters to anyone who uploads Gottlieb manuals.
Should be fairly easy to trace though, just match the wire color from the coil to the board plug, should be J4 or J6 (use your dmm to buzz it if your not sure), then follow the trace back to the transister.
Looking at a Big House manual (same series) the slingshot soloniods are on the main driver board. However, it does have several pop bumper boards mounted in the bottom cabinet as well that drives the other soloniods, so if you dont find the wire on the driver board, check the smaller boards, usually in the bottom cabinet of mounted on the bottom of the playfield.
