disjaukifa
Hey Guys,
I've got an AR02 board in a Gottlieb System 80A machine that isn't outputing 60 volts and 48volts on pins 1 and 3 on the J3 connectors. Here is what I'm seeing:
Pin 1: 00.2 volts (Should be 60 volts)
Pin 3: 00.2 volts (Should be 42 volts)
Pin 6: 4 ~ 5 volts (Should be 8 volts)
Pin 7: 4 ~ 5 volts (Should be 4 volts)
Pins 6 and 7 change pending how you adjust the pot the AR02 board. Any suggestions on where to go from here would be highly appreciated.
Disjaukifa
Disjaukifa
