gottlieb system 80 pinball
kfuller19
Permanently Banned
Donor 4 years: 2012-2015
auburn, Georgia
ANyone have a clue how to fix this acid damage on this board?
ive heard desolder the battery back and dip the board in vinegar and then resolder all the leads and contacts...
but would love some conformation before i go that route
Also if you have a working system 80 rev b mpu board i will buy it
Corrosion kit
+1 on the kit. You need to get off all the components to get the crud neutralized and cleaned up. Then replace with new. Was the same on my sad Stern MPU. Good luck with it
I wouldn't bother with the full corrosion repair kit, but go the DS1811 route. Works great!
Digikey carries the $1 part: http://www.digikey.com/product-detail/en/DS1811-10+T&R/DS1811-10+CT-ND/957029
Pinrepair said:
Thanks to Pascal Janin, there is also another way to fix the reset section with just a four parts (that replaces nearly 25 parts!) This involves using the new Dallas/Maxim Semiconductor D1811 reset chip (TO-92 package). This inexpensive device looks like a transistor, but is really a three leg chip in a TO-92 transistor package.
The advantage to the Dallas DS1811 is great: if a system80 CPU board has had some battery corrosion and perhaps some circuit board traces are questionable, the new Dallas part will not utilize most of that. So even a board with lots of corrosion can have 25 reset parts cut out, and just the Dallas installed. So most of the questionable traces on the component side of the circuit board are eliminated too, making battery corrosion less of an issue.
The Dallas DS1811 comes in three TO-92 flavors of "normal reset threshold":
• DS1811-15 = 4.13v
• DS1811-10 = 4.35v *
• DS1811-5 = 4.62v
* The best one to order is DS1811-10.
Here are the installation steps for this chip:
• Remove reset parts: chip Z1, trans Q1-Q4, diodes CR33, CR35, VR1, resistors R8, R9, R43-R50, caps C2, C25, C36.
• Install a jumper from Z1 pin 5 to Z1 pin 9.
• Install a jumper from Z1 pin 11 to Z1 pin 13. Be careful not to accidentally connect pin 12 to the jumper, as it will cause the reset modification to not work.
• Install a jumper where R45 was installed.
• Install a jumper between the two top holes of Q3 (the Emitter and Base).
• Install the Dallas DS1811 (TO-92 package) into the top pads of R50, R44, R49 (pin 1=R50, pin 2=R44, pin 3=R49). Note the flat edge of the DS1811 faces downward away from Z1, toward the dip switches.
• Retain reset parts CR34, R7 and C3.
• Note R10 and C14 can be remove or left installed. Since Z1 has been removed, R10 and C14 are no longer used, and can be removed (or left installed).
The DS1811 is installed with pin 1 going to /RESET, pin 2 to +5 volts (thanks to the jumper at R45), and pin 3 to ground (via the jumpered Q3). Also remember using the DS1811 will not replace the often damaged clock circuit chips at Z2 and Z3.
