Gottlieb System 1 Problem with Charlies Angel
jws338
Illinois
I have a Gottlieb System 1 CA. I do not get the bonus lights or scoring. The lights work when grounding the transisters. So the wiring is good to the good bulbs. I think it is in the cpu board? Anyone have any experience with this problem.
John
John
Have you done the ground mods yet? Here's a link to pinrepair.
http://www.pinrepair.com/sys1/index.htm
Glennon
Check the connector between the driver board and the CPU PCB. Also try resetting all of the audits in self test. I've had Gottliebs act up, and after clearing the memory/ audits it was ok.
-Mark
I have checked the connections and reset audits. I will try updates from marvin and pinrepair. I just installed a pascal p1 x4 in my other CA and it works fine. That is also a option for this one. But that is around $377 us.
John
