Does anyone have two Gottlieb 21 Pin Edge Connector housings? (0.156") These are hard to come by and just wondering what my options are before having to reuse the original connector shells.
The MPU to Driver board cables are commonly available, but I think those are 24 pin - any reason you can't just replace the pins in your existing ones?
Pins are relatively easy to replace, but if the housing is truly trashed/broken, that makes it tougher.
I've personally used these types of connectors in the past - just cut them to the size needed:
