wrongdon
My Stargate pin boots to random garbage on the dmd and beeps unless i unplug P1 (input) side of the aux driver board . With the aux driver board unplugged it boots fine and plays just as it should minus the flash lamps that it drives . I have been tracing wires for what seems like forever from the output side to the lamps when it hit me to leave the input side plugged in and unplug the output side . With P2 output unplugged and P1 input plugged in the game still boots to random garbage and beeping . This tells me it is not a wiring problem on the output side as suspected but rather a problem with the board itself or maybe an problem on the Mpu that is causing a conflict . The drive transistors test good .
Any ideas to isolate the problem further ?
Thanks folks .
Don
Thanks folks .
Don
