Gottlieb Pinball Pool Problem
Burt6666
Calgary, Alberta, Canada
I know someone else here had this issue as well but can't seem to find the thread.Machine boots and goes into attract mode fine but refuses to coin up or start a game.Re-seated all connections with no luck...any ideas?
Can you put the game into Switch Test?
Make sure your connectors from the coin door are good AND the coin door is wired correctly.
Check the connector on the MPU, if you jiggled one of those loose, broke a contact or any corrosion, you could have lost part of switch matrix.
