woodrailsrus
hello
i was removing the lower playfield in my gottlieb haunted house to clean it and i think when i set it down i bent 2 of the contacts on the one target that is attached to a coil. when i powered the game back on and put it in test most to test the lights (which worked and which ones were burnt out) this coil fire 2 times.......then about 1 minute later this coil started to smoke slightly. i put my finger on it and it was very hot.
NOW when i hit the contact associated with this coil, it gives me points like normal but the coil wont fire. it acts like it wants to fire but it wont (it moves very slightly) when i try to move the metal cylinder inside the coil its really tight and wont move.........im guessing that coil is now burnt and im going to need a new one?
