Gottlieb EM Target Pool issue
bpick
Nebraska
So I am new to EM's and this Gottlieb target pool has me stumped, here is what is going on.
1. At power up you can press the start button it goes through the reset process 100%, score reels reset to 0, credit decrements by one, the ball counter goes to ball one and you can play a complete game.
2. On the start of the second game, everything from above happens perfectly, BUT the score motor will not stop.
I can turn the machine off and back on again and start the game and it works perfectly again till the second game, or I can press the start button again and it will do another reset and everything is ok after that as well.
Also manually doing the reset bank does nothing, I either have to power cycle the machine of press the start button.
Things I have done.
I have checked the home switch on the score motor adjusted and cleaned, I have also checked the 0 and 9 position switches on the score reels and they are all good, the credit switches on the doors are also good.
I am waiting to put an order into PBR for some parts / schematics but I thought I would throw this out and see if anyone had any ideas.
Brad
