I've discovered an issue with the 3 target bank on the lower playfield on my recently acquired Black Hole. The target bank doesn't reset. I checked the switches, and the targets do score points and show up in the switch test, the solenoid is getting power, and fires when "jumped" with alligator clips. So, if the solenoid is good, and the switches work, what would the likely culprit be?
