Gottlieb Arena help
Phetishboy
Avon, Minnesota
So the machine powers up, lights flash, the led screen works and it coins up. No ball in the chamber, after coin up, no solonoids charge, no flippers, nothing. Where to start?
Check the slam switch and wiring to the front door, I think being in slam mode will cause this. Clays guide will show you how to "fix" on the CPU board.
I have a system 80a that has done that a couple times and it was the fuse under the playfield. If thats not the problem it could be a number of things. I'd start with the ground mods if it doesn't allready have them. Try this http://www.pinrepair.com/sys80/index.htm
Glennon
Sounds like you have no solenoid voltage. Check the solenoid fuse(s) with a meter then check for voltage at the coils.
I'm assuming you can start a game but no coils work?
