Got a BK 470 today, have a few questions
sconfu
Illinois
Read through the manual and did a 4900 and 2 sanyo's turned out great. alot brighter and sharper.
i did 3 hits each on balance and a rejuvenate on the color that was the worst
my setting were
g1 at 50v
heater at 6.3v
does tracking need be set on the gun before every balance?, or can i hit a gun 4 or 5 times then adjust tracking then check gun emission levels?
will any 10 pin arcade monitor work with a cr 23?
like nanao or NEO TEC med rez in Crusin USA?
thanks
Brian
I always remove shorts and color balance before rejuving. A lot of times those two things alone will greatly improve the picture quality. If you rejuve a color gun when it doesn't need it you are decreasing the life of the gun.
