Gorgar "System 6" starts 2 player instead of 1
gsrogers
Donor 2023-2024
Friendswood, Texas
I have a Gorgar working great but sometimes (kinda often) it will start a 2 player game when I push the start button. I adjusted the switch so I am certain it is not hitting twice.
Thoughts? Thanks
Any other switches registering multiple hits, that would indicate a driver board issue?
If cleaning and adjusting the switch didn't do it, try wiggling the wires and diode to see if there might be a bad connection in there somewhere. (you did both adjust AND clean it, correct?)
-Hans
I will check wires but I did clean and adjust. I do not see any other switch problems. Thanks
