Gorgar Right Kicker Coil Continuously Energized
buxtonore
Wixom, Michigan
I have replaced the Transistor that drives the right kicker on Gorgar I also replaced the old burned up coil,and Transistors... Q1, Q9, Q11, Q2, Q10(responsible for driving the right kicker.) Q12, Q5, Q3, Q7, Q6, Q4, Q8. No change, the coil is still continuously energized. Does any one have an idea
why it's still doing this?
Thanks,
Tony
It could be several things. I started to write up and go through them, but it gets pretty lengthy. Do you have access to the old repair guides?
In summary, it is probably an IC on the driver board (a 7408 or 7402). But not necessarily.
