GORGAR Question
Galaga007
Maryland
I just installed a Rottendog board in my Gorgar, that takes the place of two boards, the driver board and the MPU board. Periodically, when I press the button to start a game, it will automatically jump to two players, even though I only pressed the button one time. Any thouhgts on what could be causing this probelm?
Thanks,
Did it act this way with the old boards? I will assume the original boards were defective thus why you installed the RD board.
Out of curiosity, does this two player issue only happen on the first game after a cold power on?
Gorgar
I had many constant problems with the old driver and MPU boards. I don't recall if this happened with the old boards, but to answer your question, jumping to two players will happen even if the game is warmed up, and has been played for quite some time. Any thoughts?
I'd clean and adjust the start button first. Could be fluttering a bit or be gapped too close.
-Hans
Exactly what Hans said. I've heard of this exact issue happening before is why I asked if it happened only on first game cold boot.
