gorgar backglass
pacalman
Michigan
the red on gorgar is starting to flake off and i don't know what to do. do any of you think that if i sprayed the back side of the glass with a clear coat (spray can) that this would stop it? i was thinking tape off all the spots for the score and ball in paly/match and give it 2 or 3 lite coats of clear. does this sound like it would work? thanks for any help.
Yes it will help you can also then brush the bad spot in if you want i some times use plastice rap and mash the chip back down and then the next day take it off and apply one more coat.
