Gorf Wiring Harness Help - Need Picture
gsrogers
Donor 2023-2024
Friendswood, Texas
I am restoring a Gorf mini and someone had cut the connector that goes to the power supply (the output connector). I have figured out some of the wires but not all. Can someone take a detailed picture of their connector and email it to me. I am going to have to identify them and use a switcher. Thanks, Garry ([email protected])
So, you are wanting to put in a switcher right?? Not sure how a detailed pic of the connector can help you ID the wires. Its been a few weeks since I have looked at a Gorf card cage but I think the values are silk screened on the back plane board under the .156 header where the power harness connects.
If you are correct I will look under the original power supply board. The history is I bought this game with the connector that comes off of the power supply but with just loose wires. They are different colors so I am hoping to get the pin position from a detailed picture. Then I will look at the schematics to hopefully give me an idea of what it is. Believe me I am not happy to run the switcher at all but it is the easiest at this time. I may install an original style connector and try to get it back to original but not at this time. garry
Thanks "Gorfchampion" for taking the time to email me some pics of what I needed. This is alot of what this hobby is all about....helping each other keeping these dinos alive.
Thanks again...Garry
