I spent all day trying to fix my rank board on my GORF. I had some bad transistors that I swapped around and did not fix the problem. The schematic shows that Space Cadet is triggered by pin 17 through Q6. I inserted a LED from pin 17 to pin 1 and it lit, so i knew that I had some sort of control. I had a broken pin on the header that I repaired, but it did not fix the problem. I had continuity all the way back to the power supply (+5v). I had the board upside down and had the bulb in the Space Avenger slot. I just now followed pin 17 and noticed that it went to Q1. I put the transistor into the Q1 silkscreen and put the bulb in the correct slot. It now lights up and ranks me a Space Cadet.
Has anyone else noticed this error?
