gorf questions
pinkpot
WEST, Michigan
edit update as of 3/14/11
i went to nerbflongs house and he graciuously tested my gorf pcb rack...NOT WORKING SHIT!!!!!!
NEED A WORKING SET!!! THANKS FOR TESTING IT FOR ME BROTHER!
i have just purchased a nice gorf, inside was in 3 inches of dust
bords sitting in 3 inches of dust. bad power supply.
cleaned the boards and the encloser assembly and they look like new.
im gonna get a new power switcher from arcadeshop.com
does anyone have any hook up tips?
i labeled the wires before i took out the power supply.
1st time trying to put in a new power supply in.
all of everyones elses tips have worked and seem to be catching on fast,
just was wondering if anyone else has any tips...i dont wanna blow this up on the 1st turn on LOL
Why replace the power supply? The old supplies are dead easy to fix.
Also, in your picture, the power supply is still installed. One of the transformers, however, is missing.
-Ian
I agree with Retro, just get yourself a working original PS. Less hassle with connector changing and it's kept more original. I've seen them come up on the for sale board fairly often.
-Ian
was ripping all of it out and cleaning it....
does anyone know where to get an original power supply????
how can i tell if the transformer is bad?
The transformer is not bad. They RARELY fail.
You don't need an original power supply, you already have one. Just repair it. It's a dead simple linear regulated supply. It probably just needs some new caps, a couple replacement diodes (the ones in the 5V section get crispy), and the connector headers resoldered. Then, you'll probably want to replace the transformer connector in the wiring harness, the center tap pin always burns off.
-Ian
It will likely need a new molex connector for the power supply, there are a couple pins that always burn on the gorfs.
Yeah, it's the lower pin on that connector, it's the center tap of the transformer. Interestingly enough, the pin just next to it isn't populated, but is connected to the same trace on the board. So, when you replace it, populate both pins and connect them both to the same wire. Helps to spread the load over two pins so it won't burn up again.
-Ian
Definitely repair the original and do not put in a switcher. I tried it and went back to the original because the game starts to re-set randomly. I researched the problem on RGVAC & the information as to why is out there if you look for it.
Here's the link to Bob Robert's PS4011 map:http://www.therealbobroberts.net/90411.jpg
I'm pretty sure I got a rebuild kit from him, but it was a while ago.
Dokert is right. On Gorf, it's all about those connectors.:)
I run my Gorf cocktail off an old computer power supply. Works fine for me.
wow!!! thanks very much for the ultra tips, after getting more into this project.
I did find i spot of burnt connector ends. i will most certainly see about repairing the original supply... again u guys are so awesome. i couldnt have started this without your help! 1st project (ihave 16 other working games) 1st project purchased as i love this game!!! got it for 170 as is. the bezel is mint- maquees are mint-...
cannot wait to play this game!
power supply
1 of the a15f pods are fried at the solder joints... all the rest of eberything looks fine....
anyhelpers?
anyhelpers?
Those are the diodes I was talking about. You can replace them with any standard 5A rectifier diodes. The rebuild kit from Bob Roberts includes these, or you may buy some at Radio Shack or similar.
-Ian
another querstion LOL
ok now that i can get them and solder them on, do i have to do anything else because the actual board has a bit of burn, can i just clean it off???
what should i use? thanks again!
The charred marks on the board are unimportant provided that you make a good connection with the traces on the board. If the traces themselves are damaged, you will have to patch them up with little bits of wire or something.
-Ian
