FS Parts: Gorf parts (sound board, plexi) etc.
jp.jones
Dover, New Hampshire
Rating - 94.4%
17   1   0
About 12 years ago, I thought I'd like to restore a totally gutted gorf machine by accumulating parts. It didn't happen and had to move, leaving the cab behind. Before I did, I pulled absolutely everything I could from it.
Sound assembly, untested (marked 'stereo' 2/27/81'). Was pulled from a machine that had aluminum baffles. 50 shipped
Graphic plexi (tested working ;)) 60 each shipped. They both have surface scratches on the front and some minor on the back.
Rigid foam rank assembly 50 shipped.
Marquee light assembly, 15 shipped.
Original Plastic Monitor Bezel, with factory cut out in the lower right corner to accommodate the rank assembly $50 + shipping (because I don't know what outrageous amount the post office will charge to send this, as well as I have to find an appropriate box).
BAFFLED Upper control panel bezel 50 plus shipping (see pic in 5th post). The bumps that you see are where inner screws are located, causing the issue.
Marquee Brackets (I may have other brackets from the cab) 50 plus shipping
I may have other cab parts, just ask. (I don't have the back plastic monitor shield)
More pics of the plexi, added pic of light assembly and plastic bezel.
I have one but the bottom is flaking off. I wasn't going to post it, but probably a few bux plus shipping without any guarantees that it would arrive intact due to overzealous postal workers. Probably better to go with the other dude who (almost) hijacked my thread.
Thanks JP - if you have pics, it'd be great to see them. Sorry if this thread is getting hi-jacked, hopefully all good and keeps it bumped. You got any other Gorf parts you can list? I too am in the midst of a restore. Cheers
I will do that once I get home from work.
From what my foggy memory recalls, I think I had pulled the coin door, marquee brackets, A wood piece, the rigid foam rank assembly, Some other brackets, the back translite, the marquee. Possibly have the coin assembly (brass looking parts from inside the door), a coin counter, the marquee light assembly, some hacked to bits wiring, and a blank control panel with faded graphics. I also have a tube filled with random metal brackets and stuff that I'd have to look through.
I'm pretty sure there is only one assembly (you can see the rank boxes on the bezel). Sorry I didn't get to the pics, was out late last night and went right to bed.
Pics of the flaking monitor glass bezel. Some places are bubbled, and some are just hanging on and might come off if shipped.
Ok, thanks - appreciate the photos and the effort but will pass - I'm looking for a mint one and someone has reached out with one. /thanks
I have a bunch of brackets (I think I have marquee brackets, they were silver right?) that I would have to look through and would be fairly uncertain if they belong to the cab or not. I'll look and post pics tonight.
I'm pretty sure I have a power board and (I think hacked) up wood power block and transformer.
Yes they were silver aluminum looking.
I think these are the ones you are looking for.
