Gorf owners, I have a question
Riptor
Leonartown, Maryland
I have my Gorf all complete and working now, it just needs a monitor shroud/bezel and tinted plexi. I need to know what style bezel it used, how it was attatched and the same for the plexi.
If someone could post a picture of one with the monitor bezel(glass) removed that would be great.
Also, I installed some of the compact flouresent bulbs in all the holders and they look great. With 5 fixtures I figured it should cut down on heat and save on electric.
Does anyone have a source or know what number the small wedge base bulbs are that are in the joystick? Looks like im going to need a couple of those.
The bezel (sorry, I don't have a picture) is more oversized like Pac-Man/Galaxian (as opposed to the smaller Ms. Pac-Man/Galaga style. It's pretty unique, in that it has a cut-away in it for the ranking lights.
The joystick bulbs are #73's....0.08 amps at 14V....a #74 would probably work fine too...same bulb, but at .1 amp. I little more heat, I guess (maybe not suck a good idea).
Edward
Sounds easy enough, take a pac style one and cut the notch in it. Hopefully I have one of them laying around.
If you can wait until tonight, I can get you a picture....I need to do some digging out. IIRC, it even mounts to the wooden cross member with screws....just like Galaxian/Pac-Man.
Edward
I have these pics I took for someone else here of my gorf plastic bezel removed.
Pretty easy to make something similar I think. You just want to have something along the sides to help remove any glare from the rank/cabinet lights.
picture.php
picture.php
