Gorf No Audio
Forgot to mention that the issue occurred after I unplugged and reseated all 6 boards. Since then I have tried that again to get audio and can't seem to get it.
There is a fuse in the bottom of the cabinet, one in the block of three. If its blown you probably need to replace the TIP31 on the amp board. Check that first as amp board failure is pretty common on the gorfs. If you work on the amp board there are a couple resistors on there that will probably be toasted. Up those to 1/2w parts when replacing.
