Spyridon
Pulled the monitor chassis. Wow, thats a 1000 times easier to pull than a WG4600! I'm reading Bob Roberts notes on the G07 and I'm going to sleep on it - with talks of modifications and upgrades.
Mine had a 4600 in it.
My t-molding came - all 20 ft. of it (trust me, I measured that twice).
Unfortunately, Gorf needs 24 ft.
That doesn't sound right. Gorf should use less than most games since you are only doing the top section. I had some left over from when I did mine. I'll have to measure to see what it uses.
I re-measured the old t-molding from mine - 12ft exactly each side.
Darn, the joystick is still stuck - as soon as the game starts the ship moves all the way to the right. In test mode the "right" diagnostic is not lit (ie, its missing as if the joystick is pushed to the right.
So....I dunno where to start debugging it. I guess I'll tear apart the CP and start looking. I think I read on a an old thread that these optical switches? aren't available anywhere? I have another CP on another Gorf, I guess I could swap out the whole circuit board.
I think I know why I had enough. I ordered mine from Arcadeshop. You order from them by game so they have it sized already for you.
Yes, the joystick is optical. I had a similar problem with mine except once you moved up, you couldn't move back down. Clean the optics with some alcohol and reflow the header pins on the board. That fixed my problem.
Pictures man pictures! Nice work too!
