Price check for Gorf mini.
Currently using and will be sold with Gorf Free Play / High Score Save Kit. Working pattern board will also be provided and game works when High score Save Kit is removed and normal board rack configuration used.
Free play button (where front right side .25c label would normally be) works with board rack in normal configuration.
- Every so often it needs to be restarted to show bright colors on 1st Mission 1 (but also goes away on its own after 1st Mission 1). Mainly occurs when not played over extended period.
- Missing coin mechs.
- Right side has patched area and the bottom right has small chipped away area.
- CP (2 extra drilled holes) / CP art (rough after cheap GORF CPO removed) have seen better days but remaining leftover CPO residue can still be cleaned up a bit.
- 2 leg levelers weren't attached when delivered in late 2019 but were received. I never attached.
