Gorf Graphic issue
the11thdoctor
Wauwatosa, Wisconsin
I just got a Gorf that works but has a graphic issue. Upon research I found that the RAM card may be the issue. Question is looking at the attached RAM board pic, could the capacitor circled be the issue? I only ask because it is popped. (picture not actual board) Would replacing the cap fix issue or is it still possibly bad memory chips?
Its not uncommon for those caps to short out and burn up. It should be replaced but you most likely have a bad ram or two on one of your ram cards.
