You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Museum of the Game® & International Arcade Museum® Forums
Recently acquired a GORF cabinet from someone mentioning that it was stuck on the test screen and would not switch to the game itself, hopefully trying to restore it completely. Screen became very glitchy after a day at my place but after replacing the power supply it was back to normal but back to square one with the stuck test screen.
I was told that they shipped out the PCB cage to be fixed and said to be working thinking it may have been a power supply issue but i recently replaced the whole power supply board to no luck.
Buttons do work fine even showing that the Test SW and ON switch does in fact work so im not sure. It also goes blank every 20 seconds or so and then returns to the test screen. I do also see that the Rank board does not light up as I've seen in other test screen videos.
Another thing i want to mention is that after a bit on the test screen the whole screen goes black, every so often i hear the voice bank screaming "aaaaa" and stops for awhile, this is where the Rank board lights up but only for the Space Cadet when i press the right buttons. Id have to turn the whole system off and back on to return to the test screen.
Is there something specific i should look into or should i cave in and purchase a working board?
