Gorf... blue background distorts? (and only the blue background?)
Was just putting the finishing touches on our Gorf cabaret and a bit of an odd problem has crept up... the blue background(and only the blue background) will distort and kinda break up. The men on the screen, your guy, and the score seems to be alright but the background gets weird.
It doesn't happen too bad really... you can play the game but it's annoying. You can also tell the brightness is changing slightly when this happens. I'm going to try another monitor but I have a sneaky suspicion it may be a PCB issue.
Just putting the feeler out to see if this rings a bell with anyone.
BTW, I've swapped out all the PCB pins with new ones and I've replaced about half the mating harness connectors(focusing on the video signal for these)... still no change. And I've also tried a different RGB board and it was exactly the same.
TIA,
Jeff
TIA,
Jeff
