MagicMarc-er
Many older games came with slots that you could slide the boards into and out of easily. I've had a hard time finding a good source for these. I'm sure I'm just using the wrong search term or something. I don't like using PCB feet because it is a hassle when you need to remove the board. I've found a lot of "pcb guide rails" but these frequently don't have screw holes in them and, when they do, the slot is on the same plane as the hole. For mounting inside a cabinet, the slot would have to be at 90 degrees to the bolt hole.
Help?
Help?
