Good Deal?
slimdiggie
South Carolina
I found a guy selling a origial blitz. The cabinet looks to be redone but, the graphics are pretty close to original. Sound works perfect and the monitor is mint. It's the 2 player version and he is asking 400 delivered to my door step and he lives 2 hours away.
I'm also looking at a airwolf game 150 delivered non original graphics but, it does have side and front art on it.
Thanks.
I am suppose to get some better pics from him today when I do i'll post them.
probably a kit into something like MK1. If you like the game, its not a bad deal.
If you don't care about it not being 4 player, don't care about regular vs 49 way joysticks , standard vs medium rez monitor or that its not blitz 2000, then go for it.
One advantage on not having 49 ways is the cabinet will be 2 player jamma. you can drop an nba jam pcb in it and it will work no problem.
One thing you should check since its a kit is that the fan is working pushing air across the pcb. If there is no fan there, you should be concerned.
Ok would you hear or see the fan from inside the cabinet? That is cool about the nba jam aspect then I might not need to buy that cab as well. Is it easy to change a board out?
Thanks.
if it does not have the 49 ways, it should work fine 2 player just like blitz. It would be a simple board swap. You could mount both boards in the cab and move the jamma harness to change games.
As for the fan, it should be right next to the pcb. Normally the pcb is mounted on a metal plate. The fan is not that critical as it would be for vegas boardset(regular blitz runs on seattle board), but the manual shows a fan is supposed to be there.
http://www.crazykong.com/manuals/NFLBlitz.man.pdf
