Gonna replace Med Res monitor with 21" Sony VGA. BNC OK?
john2654
Donor 3 years: 2011, 2020, 2024
Rhinelander, Wisconsin
My medium res 20" monitor in my APB has a lot of burn in. I was going to do the VGA monitor swap: http://www.dragonslairfans.com/smfor/index.php?topic=630.0
My question, can I use the BNC connectors on the back to hook up to the video board or should I just go with a CGA to VGA converter?
First pic is the back of my Sony 21" CRT VGA monitor.
Second pic is what someone else did - What I'm trying to accomplish.
Attached photo is what I'm working with...If someone is interested in it...
zoom_39288_8.jpg.ashx
If you happen to have some BNC males laying around, it's worth a shot.
On a side note, 320x240@60Hz (common in circa 1990 DOS games) has a hsync of only ~15.4kHz. If the monitor is old enough to still support old DOS resolutions, it may take a med res (or even standard!) signal straight up the HD15, as long as you can part out the H/V sync signals (i.e. 5-pin monitor connection, no composite sync or SoG).
This should be useful:
http://www.monitorworld.com/Cables/hd15male_to_hd15male_pinout.html
(Note: Very few computer monitors actually support composite sync. Also, the "Mon ID" lines are used for EDID, a technology to let the monitor tell the computer what it's capable of -- for this, leave them NC, it'll assume it's talking to an "old" computer that doesn't do EDID.)
