GoldenTee Complete Question
Mike Washington
New York
Hello, I just purchased a GT Complete Cab. The Marquee says Golden Tee Fore/Complete. How can I find more info on the game?
It does not have a monitor and the guy I bought it from says it needs a power supply.
Before I go buy a power supply is there a wiring schematic I can reference?
What style of Monitor can I use? I have some WG 25" laying around.....
Thanks for the Help!!!!
Mike
Golden Tee Complete uses either a Standard Res or Medium Res monitor. The 25" WG will work for Standard Res mode but the boardset has to be set to run in standard res...
As for the PS, if it has a RED PCB it uses a standard ATX PC power supply... it does suck some juice so get a decent quality one. If it's a GREEN PCB then it uses a standard switcher arcade power supply. Again, use a quality part as it does use some juice.
The docs can be found on Incredible Technologies website I do believe.
