Golden Tee - What to look for?
Zud
Madelia, Minnesota
Besides the PCB, monitor and CP what else do I need to look for on a GT game? I have a chance to get one that I believe is complete, but not working. He stated the computer is not working. I am assuming he means the harddrive. But since I have never seen one up close I want to make sure What may be missing if anything when I go to look at this game.
Its basically a PC motherboard, in either green or red. Other than the hard drive being there, make sure it has the video card, which will be fed by a pass-through cable. Here is a pic of the inside of my Fore! 2005 with a green board. You can kinda see the video card and pass through cable at the bottom of the board near the power supply.
It has some green status LED's that let you know what it's doing. If you can work on a modern PC, 90% of this is going to look very familiar. Drop me a PM if you need a manual.
im trying to build one for someone.
found out the red board can be upgraded to big buck hunter.
GT 2005 comes with 7 courses. can buy hard drive with 29 courses for 450 ish.
different power supplies needed for red and green boards. green i think uses a computer power supply, or is it the red? both are JAMMA.
looking for more info and will contribute when i learn more. thanks for posting.
Thanks for the post. I thought it was just that simple, but wanted to make sure. I already have a green and red board. This hopefully has everything else I need. Sounds like all I will need is a new hard drive.
Not sure which one it is. I'll see on Saturday.
