golden tee trackball harness
If anyone builds 60 in 1's with trackballs, these will work for that as well.
I think you may need to move one wire, but I have made these work.
i didn't know that. thanks for the info. i'll keep 1 for myself now just in case i build another 60in1.
as of right now i still have 4 available.
which wire needs moved,that would explain why i have never got them to work
if you pull up a pic of the 60 in 1 harness from twistedquarter.com or bob roberts, then take a look at your golden tee harness, you can clearly see which wire needs to be moved (from the smaller molex that connects directly to the board)
http://cgi.ebay.com/Golden-Tee-Trac...rness-NEW-/250687068273?pt=LH_DefaultDomain_2
http://therealbobroberts.net/60tbharn.jpg
here are a couple of links, looks like 4 wires need to be moved, though I don't remember having to move that many.
