Golden Tee Sync: Need Advice
Thedoctor0907
Donor 2015
Sedalia, Missouri
So, Im having trouble with what appears to be sync on my Golden Tee. It has a Wells Gardner K7000 25". I had to replace the Jamma harness and thus, repin the appropriate connectors for sync, RBG... It appears I cannot get it to sync? Is that what this is? I removed the chassis and it looks rather toasty with some other modifications as well. Any thoughts? Easier to do an LCD conversion? Here are some pics
Yep, flip dip switch to CGA, you may have to do it a few times, as those switches are prone to dirt build up. Then adjust your Horizontal Hold, should be good to go.
